Activity › Forums › Adobe Premiere Pro › CS3.2 premiere imorts a 1 hour clip as a 19 minutes !!!!
  • CS3.2 premiere imorts a 1 hour clip as a 19 minutes !!!!
    Posted by Max Pawlikowski on September 2, 2008 at 11:14 pm
    (issue in premiere cs3)
    as in suject i importet new tape (60 min.) from the vcr … and the premiere sees only 19 minutes of footage i tried on and on … with new stuff it onece did it wright about 10 tapes ago and now nothing … Premiere on the olders pc sees it all in the wright way but its to slow to edit … any ideas … what to do …??
    … thanks … :]
    PS i tried all preesets
    Cheers
    Max
    Max Pawlikowski replied 18 years ago 4 Members · 6 Replies
  • Harm Millaard
    September 3, 2008 at 7:18 am
    Check your file system.
    Harm Millaard
  • Mike Velte
    September 3, 2008 at 10:49 am
    Right click on the drive in “my computer” and choose Properties. File system must be NTSF and not Fat 32. Convert if necessary…Search Windows Help for “Convert NTSF”.
  • Max Pawlikowski
    September 3, 2008 at 3:17 pm
    unfortunetly the drive file sytem is ntfs and the other wilder thing is that out side the premiere the filel are in wright duration. I can play the whole file for ex. in windows media player Cinema Player and otheres …. any thoughts …??
  • Eddie Lotter
    September 3, 2008 at 3:48 pm
    This may help you understand the problem: FAQ: How do I import xyz format files?
    Cheers
    Eddie
  • Mike Velte
    September 3, 2008 at 5:35 pm
    I’m guessing you are capturing via a TV card or razzle/dazzle breakout box in the Mpeg format…not suitable for editing in CS3…either convert the video to DV type 2 or use Premiere Elements.
  • Max Pawlikowski
    September 10, 2008 at 11:02 am
    no the footage was captured via fire wire and a dv vcr the footage was dv 4;3 nothing special …
    the pc is mac based vista bootacamp …
    THE ONLY SOLUTION I FOUND
    was to instal the mac version of premiere … and everything came to be wright …
    I thinking that teh fault is one the side of viste somewhere … but i dont know where ….
    any ways thanks for feedback …
    PS. the othere thing that I came on was that the Blackmagic Decklink HD Extreme works better on PREMIERE ON OSX than on VISTA.
    Ex. the files-paths from SONY EX1 are supported natively… I’ll post it on the blackmagic forum
    THERE IS HOPE THAT EVERY THING WILL CONTINUE TO RUN OK
    Cheers …
