Activity › Forums › Adobe Premiere Pro › CS3: ‘zoom’ during transition, only after rendering
  • CS3: ‘zoom’ during transition, only after rendering
    Posted by Doeke Dobma on January 12, 2010 at 6:52 pm
    Hello,
    I have a question. I have made a short film, consisting of different clips(no stills). Between some of the clips I’ve placed a transition(cross dissolve and dip to black). When I play the film in CS3 before rendering everything seems to be fine. After rendering, the film is ok, except for the transitions. When a transition occurs, it looks like the image is zoomed a bit.
    So, with a cross dissolve, clip is playing normally, but when the transition starts, the image looks seems to be zoomed in a bit, and when the transition ends, the image is normal again.
    I’ve looked in the manual and on the internet, but I can’t seem to find what the problem is. Perhaps some of you know what I’m doing wrong.
    Thanks in advance,
    Doeke Dobma
    Doeke Dobma replied 16 years, 8 months ago 2 Members · 3 Replies
  • Jon Barrie
    January 12, 2010 at 10:20 pm
    Are all the clips u r using re same frame dimensions as the timeline?
    – Jon Barrie
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Doeke Dobma
    January 13, 2010 at 9:17 am
    Hello Jon,
    Yes they are. They’re even all from the same source. Could it be that the frame dimensions from the transitions are different? Do you know where I can check that?
    Doeke Dobma
  • Doeke Dobma
    January 14, 2010 at 10:03 am
    Problem solved! Really stupid… the project was set on NTSC, the source was PAL, and the output was also PAL. I made a new project on PAL and everything was fine…
    Doeke Dobma
