Activity › Forums › Adobe Premiere Pro › cs3, where the keyboard shortcut for moving the edit line to in/out point of the selected clip?
  • cs3, where the keyboard shortcut for moving the edit line to in/out point of the selected clip?
    Posted by Reko Tomo on September 5, 2007 at 6:35 am
    in premiere 6.5,
    i can just select the clip in the timeline,
    then hit up/down arrow to go to the in/out point
    of the selected clip.
    I can’t find this feature in cs3.
    There is Q and W keyboard shortcut,
    but the edit line just jump to the
    very first / last of the sequence in timeline,
    not the in / out point of the selected clip.
    There is also Page up/down keyboard shortcut,
    but it also doesn’t move the needle to the
    in/out point of the selected clip.
    It just move to the next/previous edit line.
    any kind of answer will be greatly appreciated.
    Thanks.
    Reko Tomo replied 19 years ago 2 Members · 2 Replies
  • Steven L. gotz
    September 5, 2007 at 5:30 pm
    You can add that function using the Keyboard Customization menu, but you must select the track, not the clip. That will create a PgUp and PgDn like function but only on that track. Look for “Go To Next Edit Point in Target Track” and you will also see the Previous setting.
  • Reko Tomo
    September 7, 2007 at 7:44 am
    Thank you very much for your help.
    Yes, it worked fine now, as the needle
    won’t go to through each in/out point
    below/above of the track.
    Still wish that it can move directly
    just for the selected clip though …:-)
    without having to mark the timeline
    with slash “/” of the selected clip.
    Thank you once again.
    I really appreciate it.
    regards,
    reko
