Activity Forums Adobe After Effects cs3 to 7.0
  • Sam Moulton
    November 9, 2007 at 2:31 am
    there’s a complex procedure detailed at generalspecialist.com where you have to copy and paste keyframe data, open the data in a text editor, change things, then paste in the previous version. This means every keyframe for every layer for every effect.
    If you’re really in a bind, and you’ve got both versions on the same machine you might want to check it out.
