Activity Forums Adobe After Effects CS3 Render Stuttering
  • CS3 Render Stuttering
    Posted by Paul Rogers on July 14, 2007 at 10:55 pm
    Been using AE a long time, just loaded CS3. Preview comp works fine @ full res and 50%. Then send to render queue, checking settings, making sure no differences in fps. Animation render out, open in quicktime, the movie stutters. I then also in quicktime export to photo-jpeg in case it is a disk speed problem and the movie still stutters.
    Problem looks like 25fps to 30fps stutter, but this is not evident in preview or render settings. Also tried trashing preferences.
    Using cc partical world for starfield.
    Any ideas or is this a bug.
    It is the new retail version, not beta download.
    This does happen on my intel macbook and dual 2ghz g5
    Using latest OS and quicktime 7.2, and has not happened in AE 6.5, 7
    Cory Bauer replied 18 years, 9 months ago 4 Members · 3 Replies
  • Mike Procunier
    July 16, 2007 at 1:18 pm
    Are you rendering fields?
  • Kevin Camp
    July 16, 2007 at 6:53 pm
    have you imported the footage back into ae and gone frame by frame to see if you have duplicate frames and if they occur at regular intervals (like every 5 frames)?
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Cory Bauer
    November 21, 2007 at 5:33 pm
    I’m having a very similar problem. Rendered out some sequences at Lossless with Alpha and then placed them into a new timeline in a new project. The original renders play smoothly, but the newly created composition has a stutter issue; it’s like the framerates are different, even though everything is set to 23.98. The stutter is evident both in the RAM preview and the actual render, even though the Lossless videos placed in the sequence together play smoothly on their own. Thoughts?
