Activity Forums Adobe Premiere Pro CS3 recent upgrade problem
  • CS3 recent upgrade problem
    Posted by Kent Smith on October 22, 2007 at 1:48 am
    Anyone else had trouble with the recent upgrade? I just created, digitized, and have been cutting a new project in CS3, and for the most part, it’s going okay. But when the automatic updates wanted to upgrade CS3, I said okay. Now, no HDV projects created in CS3 are loading.
    I get a:
    [..\..\Src\Time.cpp-105] error code.
    I’m sure it’s tied with the m2t files, which I previous got when I outputted Cineform m2t files and tried bringing them back in. But here, the project was set up in Adobe HDV project settings. Cutting on a PC, dual xeon processors. Dual monitors waith an Nvidia 8800 GTS graphics card. I’m also using AspectHD, but these projects were not created in AHD settings.
    Lloyd Coleman replied 18 years, 10 months ago 3 Members · 2 Replies
  • Perry Cheng
    October 22, 2007 at 8:03 pm
    I have been having problems also with updates. I saw the updates and download it, then, after the download, it says something like “unable to locate files” and then it went away. Now when I have the program runs, it never asks me for an updates anymore and it still says 3.01 Not 3.10. Also, Bridge’s Start Meeting update never got installed either. I have reinstalled the entire program (CS3) but no help.
    Perry
  • Lloyd Coleman
    October 24, 2007 at 2:36 am
    I also had the same error code you have. I found that it only happened on HD projects and on those where the files had been moved or re-named. If I captured in Premiere and did not move them from the original capture location then they would work. I am not sure if mine started when I updated Premire or not, because I had done several things to my computer in a short time frame.
    The solution I found was this – uninstall Quicktime. After I did this all my projects work again and I can capture with a different program than Premiere, move them around and re-name them without a problem. I don’t know if it is a Premiere problem or Quicktime problem. For the time being I am running without Quicktime, but don’t know what I will do in the long term. I hope this gets figured out.
