Activity Forums Adobe Premiere Pro cs3 install third party software error
  • cs3 install third party software error
    Posted by Scott Cary on February 9, 2008 at 8:49 pm
    just purchased the adobe cs3 produciton premium pkg and did a complete clean xp install so i would have a clean slate to start. 1st disk with adobe reader and flash installed fine. 2nd disk wont autoplay when inserted so i went in manually. this contains folders for premiere, aftereffects, encore, soundbooth.
    when i click the installers individually they all get same error message “please install Adobe After Effects Third Party Contenet using setup.exe” searched through countless threads but cant find a solution. anyone have a remedy?
    thanks
    im running;
    AMD Athalon 64×2 Dual core processor 4400+ 2.2Ghz, 2.00GB Ram
    xp service pack 2
    Abit AT8 32x(ATI RD580-ULI M1575) motherboard
    ATI Radeon Xpress 3200
    raid 0 config
    Jon Barrie replied 18 years, 7 months ago 2 Members · 1 Reply
  • Jon Barrie
    February 10, 2008 at 12:12 am
    If you’ve got a legal copy you should be able to run the autorun window to install all the discs back to back from disc 1. There is no need to ask each disc to install it’s contents. You’ll get a message to put the next disc into the drive.
    – Jon 🙂
    How many editors does it take to change a light bulb?
