Activity Forums Adobe After Effects CS3 colour management is driving me nuts
  • CS3 colour management is driving me nuts
    Posted by Dermot Faloon on July 17, 2007 at 10:02 pm
    I just want it off, the way AE7 was.
    I have a dvcproHD mov from FCP in CS3 and it looks dark in the viewport and renders out even darker (animation 100%). I have turned off all colour management everywhere and it still renders dark.
    There is an option in project setting for “legacy quicktime gamma” and this renders out a bit better but still darker than the orig file. I can find no way to fix this massive issue with CS3.
    I just want it to leave my colour alone. If I cannot fix this then I cannot trust AE. I have wasted many hours on this now with no sensible solution.
    anyone?
    The same job in AE7 works with no problems at all.
    Darby Edelen replied 19 years, 1 month ago 2 Members · 1 Reply
  • Darby Edelen
    July 18, 2007 at 3:23 pm
    If you have your color management entirely ‘turned off’ then I believe AE uses your monitor’s color space as both the working space and destination space. I think it would be better to use the color management features to your advantage than to throw them out the window and expect everything to work perfectly. I haven’t looked at the help files for this particular problem yet, but I’m sure that Adobe has something in there about it.
    How did you capture/compress this DVCPRO HD footage? What is its destination?
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
