Activity Forums Adobe Premiere Pro CS3 choppy playback in preview
  • CS3 choppy playback in preview
    Posted by David Jackson on January 17, 2008 at 5:05 am
    Hi all, I’m having a bizarre problem with PPro CS3 that I didn’t have in CS2. Playback in the preview window is jittery, jumping around a few frames back and forth along the timeline.
    Audio plays fine while the video jumps around, and the video actually seems to keep up overall. Exporting works as well, so this is effectively just a nuisance, but it makes finer work nearly impossible.
    I’ve tried to preview on high/draft/automatic quality, and have a machine that should have no problem handling the footage. I’ve seen a few other people in my googling that likely have this problem, but haven’t found a solution.
    Dual 3.6Ghz Xeon
    3GB RAM
    ATI FireGL v7350 1GB
    160GB System Drive
    1TB RAID0 video/scratch disk
    The video source doesn’t seem to matter, either. It can be jittery right out of the HDV camera, or an AVI already on the computer. It’s equal-opportunity chop.
    Thanks for any suggestions you might have!
    Kyle Reynolds replied 16 years, 5 months ago 7 Members · 9 Replies
  • 9 Replies
  • Randy Mcwilson
    January 17, 2008 at 5:45 am
    Here are a couple of suggestions:
    (1) unplug your firewire cable after you finish capturing. This can free up resources that bottleneck output.
    (2) move your composer window to your PRIMARY monitor (if you have dual monitors)
    hope this helps!
    Eternity…don’t miss it for the world.
  • David Jackson
    January 17, 2008 at 6:26 am
    Thanks for the suggestions. I unplugged the firewire and docked the preview window on the primary screen, but to no avail.
    EDIT: Yanking out ATI Catalyst and reinstalling *just* the display drivers seems to have fixed the problem. Fingers are crossed.
  • David Jackson
    January 20, 2008 at 4:39 am
    …nevermind. It didn’t fix it at all. I’m really wondering if I’m going to have to reinstall Windows at this point.
  • Dave Gruchy
    October 20, 2008 at 4:15 pm
    Hey,
    Did you ever solve this problem? I’m having this issue too, and can’t find a fix anywhere. (Or anyone with the same problem but you.) It’s driving me nuts!
    -Dave G.
    La Ronge, Saskatchewan
  • Dave Gruchy
    October 20, 2008 at 4:16 pm
    Hey,
    -Dave G.
  • Ilay Kimsey
    December 18, 2008 at 9:15 pm
    hey, i was having the same problems just as you!
    video plays choppy on premiere cs3, otherwise all is well.
    nothing seems to work when trying to fix this, i’ve tried switching video cards, drivers, and windows xp versions.
    when i install premiere pro 2.0 it works just fine, but why should i use it if i’ve got cs3 master suite….damn…
    any thoughts?!
    thanks
    ilay
  • Steve Johnson
    January 30, 2009 at 4:53 pm
    I am also having this choppy playback problem in CS4.
    Help.
  • Simon Davis
    February 8, 2009 at 9:41 pm
    Hello,
    I’ve had this in CS4 too with full HD video. I read another post for CS2 somewhere, where overclocking was mentioned. If I turn off the overclocking of my CPU, I get an improvement in playback.
  • Kyle Reynolds
    April 7, 2010 at 8:55 am
    I am also having this problem, however I am not using windows
    If anyone suspects its a hardware issue let me give you my specs
    Apple Mac
    12gb RAM
    2 x 512mb DDR 3 Geforce Graphics cards
    4TB Hdd Space.
    I really dont understand why premier is so choppy, I am having serious issues trying to syncronise audio and video as premier does not let me preview very accurately.
    I was using uncompressed footage from the Canon 5d mark ii, at 30 fps interpreted at 25 fps, and scaled to 1024 x 576. Even after interpreting the footage to 25fps, it would still not sync to the audio recording which was recorded at 25 fps, so i still had to speed the footage up by 120 %.
