Activity › Forums › Adobe Premiere Pro › CS3 Capturing Problems with black bars on the Right and Left???
  • CS3 Capturing Problems with black bars on the Right and Left???
    Posted by Clint Milner on June 12, 2008 at 5:18 pm
    I’m capturing some 16:9 PAL from a Mini-DVCAM.
    When I do a batch capture the end avi file ends up looking like a squished widescreen picture with black bars on the right and left. Prior to this tape, I captured footage from the same camera, same event, and it worked fine, all in widescreen.
    Below, 2 screen shots and a little test video.
    https://www.alpha-duplication.com/good.jpg
    https://www.alpha-duplication.com/nogood.jpg
    https://www.alpha-duplication.com/testmovie.avi
    I really need some help or a work around that someone might know.
    Clint
    My project set-up is:
    General
    Editing mode: DV PAL
    Timebase: 25.00 fps
    Video Settings
    Frame size: 720h 576v (1.422)
    Frame rate: 25.00 frames/second
    Pixel Aspect Ratio: D1/DV PAL Widescreen 16:9 (1.422)
    Fields: Lower Field First
    Audio Settings
    Sample rate: 48000 samples/second
    Capture Format
    DV Capture
    Video Rendering
    Maximum Bit Depth: Off
    Preview File Format: DV PAL
    Compressor: DV PAL
    Color depth: Millions of colors
    Default Sequence
    Total video tracks: 3
    Master track type: Stereo
    Mono tracks: 0
    Stereo tracks: 3
    5.1 tracks: 0
    Submix mono tracks: 0
    Submix stereo tracks: 0
    Submix 5.1 tracks: 0
    Clint
    Clint Milner replied 18 years, 3 months ago 2 Members · 2 Replies
  • Ann Bens
    June 12, 2008 at 7:22 pm
    Go to the project window rightclic on the footage and set the interprete footage to widescreen. That should do the trick.
  • Clint Milner
    June 13, 2008 at 10:06 am
    Genious!
    Worked very well, thank you so much.
    Clint
