Activity Forums Adobe Premiere Pro CS3 and DigiBeta Questions
  • CS3 and DigiBeta Questions
    Posted by Ross Bradshaw on May 15, 2009 at 1:54 pm
    Hello All.
    I am about to put together a whole festival worth of films and before I start I just need to know if Im approaching it in the right way.Here is what I want to do:
    Using Prem CS3 (I have a Matrox RT. 2 Card) I need to capture masters edits (there will be a lot of different formats from DVCAM, DIGIBETA, High Quality QuickTime ETC) and assemble five screenings with the final foramt as DigiBeta.
    Im going to comp out analog to DIGIBETA but I haven’t work with Digi much before so does anyone know what resolution Digi is and what would be the best preset to use with CS3
    Ross Bradshaw replied 17 years, 4 months ago 2 Members · 4 Replies
  • Eric Jurgenson
    May 15, 2009 at 6:52 pm
    Matrox MPEG2 I-Frame (NTSC 720×486). Crank the quality slider up to whatever your disk system can handle.
  • Ross Bradshaw
    May 18, 2009 at 8:53 am
    Cheers Eric
    I’m in europe so I take it that I should use PAL 720×576? With a good bit of RAM I should be able to crank up the slider shoudn’t I?
  • Eric Jurgenson
    May 18, 2009 at 12:18 pm
    I believe it is more a disk speed factor. Depending on transitions, audio, etc., you might be able to get 100Mb/s playback from a single SATA drive. For higher performance, multiple track playback, etc., you would want a stripe set or an array (or use a lower the data rate).
  • Ross Bradshaw
    May 19, 2009 at 11:58 am
    Ok that all makes sence. Cheers for you help Eric
