Activity Forums Adobe After Effects CS3 23.98 bug?
  • CS3 23.98 bug?
    Posted by Anthony Dupsta on February 7, 2008 at 8:44 pm
    In CS3 on the PC. I have an image seq rendered out at 24fps. Final delivery will be an image seq at 24 fps.
    But for review I built out quicktimes. I have imported the seq at 23.98 into a 23.98 comp to render a QT at 23.98fps.
    In this comp frame one is slated text.
    Frame two is when the image seq starts.
    This rendered quicktime produces a stutter or random hold frames.
    Now when I take the same comp but have the image seq begin on from one, the quicktime is flawless.
    I have recreated this in AE7 and have no problems. Only in CS3.
    Please see if you can recreate the problem.
    My solution for now is to add a one frame handle on the head of the image seq. So the imported seq. starts on frame one and not frame 2.
    I lost tons of time trouble shooting this, hope this helps, maybe someone else can chime in here.
    Anthony Dupsta replied 18 years, 6 months ago 20,451 Members · 4 Replies
  • Anthony Dupsta
    February 8, 2008 at 8:11 pm
    Hey will someone re create this
    WinXP AE8
    New comp 23.98fps
    Import image seq at 23.98
    Start image seq at frame 2 (not frame one.)
    overlay a frame counter in @ 23.98
    Render a QT, PhotoJpeg. 23.98fps
    Does it play back jerky.
    Thanks so much
  • Anthony Dupsta
    February 10, 2008 at 4:25 am
    Have you tried to re create it. In this case weather it is HD or SD is not the issue, it is not a bitrate issue. Again, the issue is what looks like a hold frame. When framing forward and watching your burn in counter, I can see the frame counter is moving but the quick time has a bunch of hold frames which give it that strobe feel. I think it is a bug in CS3. Again, just try to set this up SD or HD in AE8:
    Comp is 23.98.
    Image seq is imported at 23.98
    23.98 Frame counter to help verify the frames.
    Start image seq at frame 2 of comp.
    Render QT photo jpeg.
    Again, this same set up works perfect when the image seq starts at one, it only strobes when images seq starts at frame 2 of comp.
    I have tested this on three diff systems, and one being a mac.
    AE7 is the only one that will render out a 23.98 QT the way I have it set up.
    I just want to verify that other people are getting this hic up.
  • Anthony Dupsta
    February 12, 2008 at 8:33 pm
    IF anyone has a second to re build this comp as described above it would be helpful to know this issue is valid.
    Thank you
  • Anthony Dupsta
    February 15, 2008 at 9:24 pm
    Dave or any other brave sole,
    If you have a copy of AE8, do me a favor.
    Make a comp at 23.98 or 23.976 it does not matter in this case.
    IT can be SD or HD also.
    Import an image sequence.
    start the image sequence on the second frame in the comp. so the first frame is blank.
    Render out a QT, lets say Photo jpeg.
    Play back the QT and verify the hold frame or strobe playback.
    Your image sequence will need some movement to see the hold frame.
    Thank you
