Activity Forums Adobe Photoshop CS2 or CS3 won’t open files on a Mac – HELP!
  • CS2 or CS3 won’t open files on a Mac – HELP!
    Posted by Bill Thomas on September 11, 2008 at 2:12 pm
    After moving my G5 with OSX Tiger and Photoshop CS2 and CS3, I now cannot open any documents in either version. It just sits there with the beach ball.
    I tried trashing preferences, but that didn’t help.
    The only thing that I know is different is that there is no internet connection to the computer yet.
    Does it have to connect to Adobe for some reason? I’ve noticed in the past that it wants to connect every so often.
    My last resort is to re-install, but I’m hoping there’s some easy solution.
    Thanks all,
    Bill
    Tony Johnson replied 13 years, 1 month ago 5 Members · 5 Replies
  • Jeff Kelley
    September 12, 2008 at 9:45 pm
    Can you create new Doc and save them and re-open them?
    http://www.willinois.com
  • David Liban
    September 15, 2008 at 12:57 am
    I am using a PowerPC dual processor, and recently upgraded to Leopard. Now Photoshop will not launch. It works fine on my Intel Powerbook, but cannot get it to open. I’ve reinstalled, dumped the preference file, and repaired my permissions. Nothing seems to work. Any suggestion would be appreciated.
  • Bill Thomas
    September 15, 2008 at 2:31 am
    Well, after lots of internet searching, I figured out what my problem was.
    I had a CD in the disc drive and for some reason there’s a glitch where PS CS2 or CS3 won’t open a file unless that media is ejected. Weird, huh???
    Hope that helps!!
    Bill
  • John Cordova
    November 4, 2008 at 8:56 pm
    Bill,
    I was having a problem that I was stressing so bad about. I thought I was going to have to spend some major $$ on…money that I don’t have. Anyway, long story short, I came upon a response of yours to a question I had and you have saved the day!!
    Thanks so much. I was already going to have someone re-install the entire Mac OSX system ‘cuz I was going crazy. I installed & re-installed CS3 several times and kept having the problem of Illustrator not opening up my files (couldn’t get a thing done in the last 5 days) until I read your post. I ejected the CD I had in the machine and voila!, it worked!
    Thank you! Thank you! Thank you!
    – John Cordova
    john@gitanodesign.com
  • Tony Johnson
    July 30, 2013 at 8:52 am
    I had trouble this morning with files not opening in PS. The problem was the CD in the drive just as you said! Thank you so much, you’ve saved me a lot of time and money!
