Activity › Forums › Adobe Photoshop › CS2 multiple images?
  • CS2 multiple images?
    Posted by Kennon Shain on November 4, 2005 at 6:28 am
    Hello,
    I’m an extremely novice Photoshop user, so please forgive my simple question. But I heard that with CS2, you can scan in multiple images together, and then CS2 will separate the images for you. If I could scan in 6 pictures at once, instead of 1, that would save ridiculous time. Is this possible?
    I’m currently using CS1, but would make the upgrade if that was the case.
    If not-are there any good scanning programs for Mac OSX (10.3.9)? I’m producing more slideshows, which means LOTS of scanning.
    Thanks for any advice-
    Kennon Shain
    PowerMac G4 (Quicksilver)
    Dual 1 GHZ
    1.5 gig RAM
    OSX 10.3.5
    Final Cut HD
    Kennon Shain replied 20 years, 11 months ago 2 Members · 2 Replies
  • Richard Harrington
    November 5, 2005 at 11:16 pm
    File>Automate>Crop and Straighten is the command.. you can scanmultiple at once that run that command to sepearate them into individual docuemnts
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • Kennon Shain
    November 6, 2005 at 12:14 am
    Much thanks-
    It looks like I have that command in CS1, so I’m going to give it a shot tonight-
    Ken
    Dual 1 GHZ
    1.5 gig RAM
    OSX 10.3.5
    Final Cut HD
