Activity Forums Adobe InDesign CS2 : bullet alignment
  • CS2 : bullet alignment
    Posted by Kevin Bath on November 26, 2007 at 12:35 pm
    Simple question – I hope – but been scratching my head for a while over this one.
    Been playing with the paragraph styles for a while, but cannot find any way of bringing the secondary lines (i.e. if a single item on a bullet point list runs to more than one line) in, so they line up with the first line.
    How do I control the tab/indent of these secondary lines?
    Many thanks,
    Kevin.
    Susan Appler de los rios replied 17 years, 10 months ago 2 Members · 1 Reply
  • Susan Appler de los rios
    October 2, 2008 at 7:56 pm
    Use the command backslash key after the space between bullet and text that follows. it will align all as long as you don’t use a paragraph return between lines. You won’t need to manually end lines until the next paragraph return.
