Activity Forums Adobe Premiere Pro CS2 and CS3
  • CS2 and CS3
    Posted by Zach Meissner on August 21, 2008 at 3:12 pm
    I currently have Premiere CS3 installed on my computer, but want to take advantage of my RTX100 card. I am aware that it will not work will CS3, but i am wondering if i can also have Premiere CS2 installed at the same time. Not sure if it will cause any conflicts. Thanks!
    Eddie Lotter replied 18 years ago 2 Members · 1 Reply
  • Eddie Lotter
    August 23, 2008 at 12:47 am
    You can run PPro 2.0 and CS3 together without a problem, however, throwing Matrox into the mix might be problematic.
    What I would recommend is removing both versions of PPro then installing in the following order:
    1. PPro 2.0
    2. Matrox, plus all updates
    3. PPro CS3
    Cheers
    Eddie
