Activity Forums Maxon Cinema 4D cs-tools: cluster -problem renderingobjects
  • cs-tools: cluster -problem renderingobjects
    Posted by Eugene Hooper on May 26, 2009 at 5:30 am
    Wow this is frustrating, I’ve been working on a short, simple animation using the cs-tool cluster. I’ve animated a house emerging from under a plane using bloom but I wanted additional trees to pop out of the ground as well. So I made a few trees using a basic cylinder for the trunk, and a capsule object as the tree top (it also has a taper object to make more of a point to the top of the tree)…anyway, the problem is, I am able to render out a single frame but when I automate it to render out all frames 0-65 the trees do not appear at all. The same goes for when I make a quicktime preview. I made my tree objects editable which I believe is part of the problem as before, my primative shapes (well, only the tree trunk cylinder) would show up. Any ideas?
    Help would be appreciated.
    Regards, Eugene
    Eugene Hooper replied 17 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
