Activity Forums Maxon Cinema 4D CS MoCam Timing Issues
  • CS MoCam Timing Issues
    Posted by Ron Moore on January 21, 2013 at 12:56 am
    I’m using Cinema 4D R12 Broadcast and everytime I setup camera moves around my scene with CS MoCam I’m always way off in estimating where the camera will be at certain marks where it needs to be in the animation. I usually start placing waypoint cameras at strategic points, setting the Duration(frames) as the length of time at each waypoint. I’m always done with my camera moves way ahead of the final frame count and am certain I must be setting it up incorrectly. Even when I preview the MoCam movement it always finishes up quite a bit before what the total of each waypoint Duration(frames) adds up to be. Any suggestions?
    Ron Moore replied 13 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
