Activity › Forums › Adobe Premiere Pro › CS 3.2 Please, what is the size limitation in pixels when importing stills?
Posted by Bruce Pelley on August 17, 2011 at 5:10 pminto the timeline?
Source DSLR is a Nikon D-90.
Trying to find out how much to crop to squeeze it in !
Thanks in advance.
Bruce Pelley replied 15 years, 1 month ago 5 Members · 5 Replies -
Vince Becquiot
August 17, 2011 at 5:41 pmI wouldn’t put any thing over 4000×4000 pixels. This would likely make it a render hell.
Not sure if this is still the case, but any pictures scaled down over 50% used to cause huge render hits.
The best way to go about it is the create a macro in Photoshop to resize all your images. Photashop also happens to scale better than Premiere.
Vince Becquiot
Kaptis Studios
San Francisco – Bay Area -
Jeff Pulera
August 17, 2011 at 5:42 pmPretty certain it is 4000×4000
Jeff Pulera
Safe Harbor Computers -
Todd Kopriva
August 17, 2011 at 8:49 pm> Photashop also happens to scale better than Premiere.
That’s true before CS5, but not in CS5 and later.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Bruce Pelley
August 18, 2011 at 12:18 amTo All:
The dimensions of the pictures from the D-90 are 4288 by 2848.
I shrunk the pictures to about 94% of original size with a program called Irfanview since I do not have full-blown Photoshop. Was just under 4,000 pixels
Bingo!! Imported just fine.
Unfortunately, after I added a color matte and then exported it the quality deteriorated quite a bit compared to how it looked when imported.
So that discovery that leads me to the next question.
What’s the best method to export a “frame” after it’s been edited which should yield the best quality?
