Activity Forums Adobe Photoshop CS 2 RAW?
  • CS 2 RAW?
    Posted by Amish Ed on December 27, 2005 at 9:56 pm
    I shoot a lot of teeth on black backgrounds, and models on white backdrops and both types of images really throw off the Auto finction. It’s really anoying to have to always pull down the menu and turn off the Auto Adjustment. I have my own image settings profile, but can’t find a way to make RAW default to that, so I’m wondering if there’s a way to disable the Auto Adjustment feature in the RAW converter? Checked the archive, but no luck.
    Amish Ed
    Dual 2Ghz G5, 4GB, running 10.3.6 w/QT 6.5.2, Black Majic DeckLink, AE Pro 6.5 w/BCC and Invig. 3D, PS CS2, AI CS2, FCP HD
    Amish Ed replied 20 years, 8 months ago 2 Members · 4 Replies
  • Richard Harrington
    December 30, 2005 at 4:21 am
    You can color correct first..then apply settings to others… also can Use Image Processor Script… details on both in Onlione Help for step by step
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • Amish Ed
    December 30, 2005 at 4:00 pm
    Thanks Richard, sounds like I’ll just stick to the same way. The auto settings are usually so far off it’s easier to do it myself.
    Amish Ed
    January 2, 2006 at 11:46 pm
    I amnot saying auto… you can tell Photoshop to use the corections from the first image as the corrections for the rest coming from the same “roll”
  • Amish Ed
    January 3, 2006 at 6:59 pm
    Gotcha Richard. I do make use of that feature which is very helpful.
    Amish Ed
