Activity Forums Blackmagic Design CRT monitoring solution
  • CRT monitoring solution
    Posted by Shawn Strong on July 24, 2012 at 1:12 pm
    I have a 2010 MacPro 2.4G 8-core (12G RAM) w Radeon HD 5870, using FCPX to Davinci Resolve and want to monitor on a Sony PVM-14N6U. Is this possible? Nothing above HD.
    Richard Cooper replied 14 years, 1 month ago 2 Members · 1 Reply
  • Richard Cooper
    July 28, 2012 at 9:52 pm
    The Sony PVM-14N6U is a standard def monitor so you wont be able to monitor in HD but if SD is all you need, then you just need to get a Black Magic i/0 card to send a proper NTSC video signal out from FCX to our Sony PVM-14N6U. No way you can (or should for that matter) monitor from your Radeon HD 5870.
    Good Luck!
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
