Activity Forums VEGAS Pro crossfades
  • crossfades
    Posted by Yarin Manes on April 7, 2007 at 8:25 pm
    im going crazy here tryin to work with sony i used to work with other utils but because of certain reasons i moved to sony and i can’t understand how the crossfades works, i diabled to auto crossfades and if i wanna do crossfades between 2 tracks on same chan its mixes between them i get this jumping tracks while all i wanted to do is lower gain a bit and then raise it up again,i know there are diffrent typed that sony offers iv tried them all but dosent work like the way i want i can’t quite play with the fades as i want to. any idea’s ?
    Edward Troxel replied 19 years, 5 months ago 2 Members · 1 Reply
  • Edward Troxel
    April 7, 2007 at 11:00 pm
    Turn auto-crossfades back on. Now, to create a crossfade, you simply overlap two events ON THE SAME TRACK. You don’t need “A/B” track editing.
    If you want to crossfade across tracks, you’ll have to manually add the fade-in/fade-out on the various events on the various tracks. Much easier to just overlap the events with auto-crossfades turned on.
    Edward Troxel
    JETDV Scripts
