Activity › Forums › Apple Final Cut Pro Legacy › crossfade issue
crossfade issue
Posted by Dustin Ward on April 1, 2010 at 6:38 pmRight at the end of my crossfades my color correction pops on my footage. Any ideas why that would happen?
John Fishbackreplied 16 years, 5 months ago 3 Members · 2 Replies
Jerry Hofmann
April 1, 2010 at 7:36 pmAre the rendered? Do your sequence settings match the properties of the source clips, and what are these settings?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
John Fishback
April 1, 2010 at 8:25 pmDid you render the transition? Sometimes, even if there’s no render line, the transition needs be rendered.
Make sure “Full” is checked in the Sequence menu > Render All menu, select the transition and render. I’ve seen this jump at the end of a transition before, I’m not sure why it happens, but the render often fixes it.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
