Activity › Forums › Apple Final Cut Pro Legacy › Crossfade in 23.98 timebase choppier than 29.97i
  • Elijah Lynn
    April 25, 2011 at 7:49 pm
    If the sequence is fully rendered, how would that affect 23.98 progressive?
  • Jeremy Garchow
    April 25, 2011 at 8:01 pm
    If the frame rate is set to half, it will playback half the frames, regardless of frame rate.
  • Elijah Lynn
    April 25, 2011 at 8:20 pm
    Right but assuming that everything is set to full frame and quality and I have my sequence fully rendered, how would having an output to a reference monitor be better other than color grading?
  • Jeremy Garchow
    April 25, 2011 at 8:32 pm
    [Elijah Lynn] “Right but assuming that everything is set to full frame and quality and I have my sequence fully rendered, how would having an output to a reference monitor be better other than color grading?”
    Because, it shows what you really have an doesn’t halve or quarter the resolution of your video. The viewer/canvas are an extreme approximations of your video. A capture card forces correct aspect ratio, color, gamma, and frame rate. Basically, it forces QT to play nice.
    Jeremy
  • Elijah Lynn
    April 25, 2011 at 8:34 pm
    [Jeremy Garchow] “If the frame rate is set to half, it will playback half the frames, regardless of frame rate.”
    I think I get it now, your original comment could have been, “check to make sure the frame rate is not set to half”. That makes perfect sense now and I will be sure to check that next time I am at the studio!!!
    Thanks Jeremy!
  • Jeremy Garchow
    April 25, 2011 at 8:59 pm
    [Elijah Lynn] “I think I get it now, your original comment could have been, “check to make sure the frame rate is not set to half”. That makes perfect sense now and I will be sure to check that next time I am at the studio!!!”
    It’s not necessarily only the frame rate, but dynamic rt in general. You have to check that pulldown menu just to be sure.
Page 2 of 2
