Activity Forums Maxon Cinema 4D Cross Section question
  • Cross Section question
    Posted by Dean Chapman on January 2, 2013 at 4:11 am
    I’d like to use near clipping (within camera settings) to achieve the same effect as you would get when cutting an object in half with a Boolean. A boolean object gives me a new object that looks like it’s got inner mass.
    Near clipping enabled gives me a nice easy cross section of objects…..but the result is always geometry that looks like it’s paper thin with no inside mass. Is there a way to see the thickness/inner mass of an object while using near clipping? I don’t want to use Booleans for everything because they tend to be problematic in other ways…
    Or is there another way to achieve nice efficient cross sections of objects without having this “hollow” looking geometry?
    Dean
    Dean Chapman replied 13 years, 7 months ago 2 Members · 2 Replies
  • Brian Jones
    January 3, 2013 at 6:00 am
    since geometry is always “hollow” (at least with a Near Clip – I think it would just be too difficult – time consuming – to have to be aware of every point inside a volume) I think you have to deal with booleans. I think you want the objects to be solid (rather than hollow but with thicker walls)? You might want to look at rBoole here https://www.plugins4cinema4d.com – it does booleans with the alpha channel rather than with geometry like the built in boolean so you don’t get the problems with rendering artifacts that you can get with standard booleans
  • Dean Chapman
    January 6, 2013 at 3:36 am
    Thank you Brian,
    I’m using the plug in now, and it helps for sure.
    Thanks again,
    Dean
