Activity › Forums › VEGAS Pro › Cross-fading tracks which are chroma-keyed.
  • Cross-fading tracks which are chroma-keyed.
    Posted by Stewart Bourke on December 21, 2014 at 3:18 pm
    SVP 12, BCC9
    I have an issue when cross-fading between two events which have been chroma-keyed.
    I use a solid-black with a fade to fade of a chroma-keyed track and the track below it – otherwise the fade does not ‘look right’ – i.e. the chroma-keyed track becomes transparent as it fades and the lower track fades through.
    I want to cross-fade between the two keyed clips, but when I overlap them the overlap interferes with the chroma-key, and so you see some of the green-screen.
    The problem with using solid-blacks and then fading them is that it blocks everything below it out, loosing any cross-fade.
    The only thing I can think of at this stage is to render them out as separate tracks chroma-keyed and then reimport them, but that seems like a very long-winded way around..
    Any suggestions appreciated.
    Thank you
    STBO
    John Rofrano replied 11 years, 9 months ago 2 Members · 9 Replies
  • 9 Replies
  • John Rofrano
    December 21, 2014 at 5:15 pm
    [Stewart Bourke] “I have an issue when cross-fading between two events which have been chroma-keyed.”
    I’m not seeing this behavior. Inherently ChromaKey uses two tracks. Are you sure that you are overlapping both tracks with other media? In other words, you should be cross fading 4 events, 2 on each track (i.e., the keyed clip and the background x2).
    I just chroma keyed a clip using BCC Chroma Key and I created a transition with another chroma keyed clip and the transition was fine. Then I created a transition with some generated media on two tracks and again the transition was fine. I did not see the green screen on either transition.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Stewart Bourke
    December 21, 2014 at 5:25 pm
    John,
    Thanks for the reply. I did make sure I was cross-fading both sets of tracks. It is a bit difficult to describe, so I give below a picture which shows the chroma-key ‘interference’
    I have put the cursor directly in the middle of the cross-fade. You can see the green-screen of the image I am fading up appearing over the clip I am fading out.
    I am using BCC 9 Chroma-studio added as a 2:1 composite.
    Stewart
  • Stewart Bourke
    December 21, 2014 at 5:45 pm
    John,
    Re-reading your reply I saw the comment ‘ I created a transition with another chroma keyed clip’.
    Is this something different to just dragging the start of the second event over the end of the first event to create a cross-fade, or should I be doing something more ‘formal’?
    Stewart
  • John Rofrano
    December 21, 2014 at 6:57 pm
    [Stewart Bourke] “…added as a 2:1 composite.”
    I believe that might be your problem. 2:1 composite affects the entire track and thus all of the clips on the track. I know you probably did this to use light wrap but try it as an FX on the event and I believe the problem will go away.
    ~jr
  • John Rofrano
    December 21, 2014 at 6:58 pm
    [Stewart Bourke] “Is this something different to just dragging the start of the second event over the end of the first event to create a cross-fade, or should I be doing something more ‘formal’?”
    No, I inaccurately used the term “transition” but I really only created a cross-fade like you did. I think the 2:1 composite is what’s causing your problem.
    ~jr
  • Stewart Bourke
    December 21, 2014 at 9:52 pm
    John,
    I never thought to try that – thank you- that looks like it did the trick.
    The only issue I have is the presets – presets saved in 2:1 do not show up when you add the effect to the event – what a pain!!
    The lighting wasn’t that great – so there had been a lot of adjustments made to many parameters to get a good key
    *EDIT* – strike that – presets saved within the Vegas preset option do not show up – BCC presets do – you can save and load them – all working now.
    Thanks for your help.
    Stewart
  • John Rofrano
    December 22, 2014 at 9:08 pm
    I’m glad that worked and as you figured out, if you save the preset from with BCC it will always be available regardless of how you apply it.
    ~jr
  • Stewart Bourke
    December 22, 2014 at 9:18 pm
    John,
    I have to say your tutorial on the BCC9 chroma-studio was a lifesaver. Absolutely amazing how poor keys can be fixed.
    Stewart
  • John Rofrano
    December 22, 2014 at 9:25 pm
    Yea, everyone demonstrates with perfect footage… I wanted to use something difficult to really show what can be accomplished. I’m glad you found that useful. 😉
    ~jr
