Activity Forums Maxon Cinema 4D Cross fade with textures
  • Cross fade with textures
    Posted by Daniel D’avoine on April 12, 2011 at 11:24 am
    I’m still a bit of a beginner in Cinema, will try and explain it the best I can.
    I have two materials applied to a single set selection and want to mix between the two, cross fade, with the material i applied second i added a transparency channel animating from 0-100%. This works in the preview window however when i chuck it through the render queue the transparency channel is applied to both materials? Anyone know why this is happening?
    I am working this way a video textures where taking an age to export, and work with in general.
    Dan
    Daniel D’avoine replied 15 years, 4 months ago 1 Member · 1 Reply
  • Daniel D’avoine
    April 12, 2011 at 11:46 am
    Ok someone on Twitter pointed me towards the layer shader which helped me out. Hope this helps if anyone else has the same problem.
