Activity › Forums › Web Design (WordPress, Joomla, etc.) › Cross Fade Image Gallery Messy On First Load
Simon Matthews replied 12 years, 9 months ago 3 Members · 34 Replies
Curtis Thompson
November 2, 2013 at 5:09 pmhello…
well – raw javascript is loaded in the dom in the order received (so to speak). for years it was considered standard practice to put all your javascript in the head of the page, but lately the more correct way is to put it right at the foot of the page before the end body tag, but it’s not something that is written in stone. where you put a script block technically makes no difference, and it was/is put in the head primarily just to keep the body clean…but there is a valid argument for having it load last on a page behind everything else.
here’s a good summary of this:
https://elegantcode.com/2010/03/30/your-javascript-goes-where/
one thing to note – if you have something in a document ready or a window load block, that will not happen as it is found, but rather after either the document (dom) is ready or the window is fully loaded. it’s a subtle difference, but technically window load comes after that. but if you have something in one of those blocks, no matter where they are in the page, they will happen then and not as they are discovered during loading.
does that help clear it up a bit?
sitruc
Simon Matthews
November 3, 2013 at 11:16 amHi,
I was a bit confused, wasn’t sure if the script was meant to be split into two separate chunks, with the “// Usage” chunk going in the body and the code above that to go in the head. I’m guessing now that it all goes together in one single chunk?
Anyway, I’ve tried the script at the bottom of the body and it doesn’t work for me at all. I tried the JavaScript and the jQuery versions (copied and pasted, then changed the names of the images), both did nothing to change the way the page loaded. The banner still appears line-by-line instead of instantly.
Tell you what, here’s a link to my website so that you can see how the banner loads down the page instead of instantly (with an empty cache). By preloading the images I was hoping to avoid the way the banner appears down the page.
The reason I was reluctant to show you my website at first is because I am offering a web design service – and I’m far from an expert on the subject, but to hell with it, you’re in on my secret now! 😀
Simon.
Curtis Thompson
November 3, 2013 at 6:17 pmhello…
any web page is going to be a top to bottom thing…so in terms of order of javascript and if it should be in a block – what’s above something else will happen first. how you set it up beyond that is layout preferences, although it is standard practice to group js code into blocks or an external file if it needs to be reused…
so here’s an example i made on jfiddle:
https://jsfiddle.net/sitruc/WhyGD/
you can see the order things are output in there. i added a wrinkle to it to make a point, which is the bar() function – because it is a function, even though it is above the document ready, it won’t be run until it’s called, which i do in the document ready block. you can play around with that to see the order of things to get a better feel for it.
however here, i think you can eliminate 99% of your load issues by simply reducing the file size of your slides – they are *HUGE* by web standards (500kb each!) – i saved one here as a 60 quality jpg out of save for web in photoshop and it looked just as good and was only 40kb – 90% file reduction. right now you are loading 6 images – assuming they are all like the first one and 500kb each, you’re loading 3mb of images, whereas reduced to jpgs, you could be loading 240k – so 6 images for half the file size of one of your current ones.
also – you are preloading them twice – once at the top of the page, and once at the bottom. you should remove one of those. but i’m betting if you make these 30-40kb jpgs, all your flickering you’re seeing will go away and you can get rid of both of the preloads…
sitruc
Simon Matthews
November 4, 2013 at 10:00 amHi, thanks for explaining the order of JavaScript. At the moment I have put learning JavaScript on hold as it was getting too much for me with all the animation, Cinema 4D and After Effects etc. I’ve resorted to just copying and pasting for now without really knowing what’s going on. The way things seem to be going with me though, I may end up concentrating more on understanding JavaScript instead of animation.
I didn’t realize I was preloading twice? There’s some script at the top which is greyed out – is this what you are referring to?
With the image sizes, what I plan to do is finalize the page and then compress the images. I’ve already changed the banner images several times during development, so to avoid repetitive compressing I will do it all at the end. I probably wouldn’t have uploaded the site to my host yet, but I’m not sure how to view pages in my browser when there is a contact form included.
So you say that any web page is a top to bottom thing. I understand that, but I thought that by preloading the images they would display more quickly, as though they were in the cache? Isn’t that what preloading is? If not then I don’t see any point in preloading.
Simon.
Curtis Thompson
November 4, 2013 at 5:34 pmhello…
i see your top preload is commented out yes. preload is typically used when you are trying to have a mouseover element or another bit of code that will show an image not otherwise loaded initially. after discovering the massive size of your images, i believe that i had misinterpreted your issue, and that a preload is probably not necessary because your images are all loaded in the div html code in the cycle at load time. therefore you can probably get rid of all preload.
however, we go back to a chicken/egg problem – you are trying to fix a problem where you have images flickering in the cycle, but you are using giant images that take several seconds to load. but then you mentioned here that they were just temp placement images until they were finalized…so in that sense, you are trying to fix a problem that won’t be a problem once you use the final properly sized images, yes?
try making them jpgs that are as small as possible wrt file size to see if it gets rid of your problem (after you also remove the preload)
sitruc
Simon Matthews
November 4, 2013 at 5:53 pmHi,
Well yes, compressing the images will make them load faster onto the screen but still not fast enough to eliminate seeing them load up down the screen I don’t think, which is not as pretty as having them load instantly. Once the images are cached they appear more instantly. I presumed preloading images would have the effect of delaying anything being displayed on screen until the images are loaded, then displaying the images in a more instant way, as though they were cached? This is not an issue that is vastly important to me but I thought it might make the loading slightly neater and I would use it if it was available.
While we are on the subject, can you recommend the best way to compress JPeg images? Can it be done from within Photoshop or should I use a compression application or website?
Simon.
Curtis Thompson
November 4, 2013 at 6:12 pmhello…
[Simon Matthews] “Well yes, compressing the images will make them load faster onto the screen but still not fast enough to eliminate seeing them load up down the screen I don’t think”
have you verified this? it’s why i suggested creating a single simple page that only does this image cycler, and also do it using final production-size images. if it still flickers, then you can work solely on it with additional css and javascript tricks to get it working. that said, his basic demo:
https://www.simonbattersby.com/demos/crossfade_demo_basic.htm
has a few 80kb images and suffers no flicker issues. therefore, i’d guess that it’s also other stuff on your page – you have a ton of other images and all are png files that seem to average around 30kb – when i cleared my cache and ran firebug, it totaled 4mb (!) of images – you shouldn’t ideally be at more than 10% of that worst case. so you are probably having flickering because of the large volume of content (images) on the page. that’s why you should make a simple page loading final compressed images – if you don’t see it there, then you know it’s not the culprit.
wrt saving – save for web in photoshop is more than up to the task for saving web-ready image files – go with that…
sitruc
Simon Matthews
November 4, 2013 at 6:48 pmHi,
Well I’ve seen the issue occur lots of times when loading other people’s websites, so I guess that has verified it for me as an issue that exists. For example, it occurs slightly when loading Video Copilot’s website. I think I’ve seen it occur on one of my own sites after image compression but can’t answer with 100% certainty on that one. I’m pretty sure it occurs, but obviously to a lesser extent. I don’t see much point in comparing my full website homepage that includes a 900×400 pixel banner to a page consisting of just a small cycler in the corner of the page. The smaller page is going to load up quicker isn’t it.
As I think I said earlier, I have already tested the image cycler on a page of its own. When the cycler is on a page of its own the issue is barely visible. Unfortunately my image cycler is on a website with a lot of other information, which slows down the process, making the issue visible. Is it possible to preload images so that nothing is displayed on screen until the images are loaded? This is what I am asking. It’s not essential but it would be nice to know. There’s either a way or there isn’t. If possible I’d like to know if there is and thought you might be able to tell me.
Your JPeg image compression advice is duly noted and will be utilized in the future! Actually, I had never noticed the option for saving for the web in Photoshop until you mentioned it, so thanks for that! 🙂
Simon.
Curtis Thompson
November 5, 2013 at 1:26 amhello…
[Simon Matthews] “There’s either a way or there isn’t. If possible I’d like to know if there is and thought you might be able to tell me.”
there is a way – i didn’t look at his code specifically but being a javascript programmer for years now, i can tell you that there’s a way to either (a) alter his simple example or (b) just write your own…in all likelihood it would be the addition of a mixture of css and a simple js loop to check if the image is loaded and show it when it is. could even be pure css – again i didn’t get too far into his example.
in your case, however, since learning javascript is not a focus right now, i’d suggest that you just leverage an existing plugin for this functionality (all the plugin will be is the same thing but with some wrapper and additional functionality around it that insulates you from the guts of the thing) – there are a million of them that would do just fine. i think his was just a case of writing a simple example that didn’t require the overhead of a plugin, but at that level you have to know the code.
this one in particular is very easy to use – give it a shot!
https://jquery.malsup.com/cycle/
sitruc
Simon Matthews
November 5, 2013 at 12:35 pmHi,
Thanks, I just worked out a simple way to do it actually. You just add display:none to cycler image.active in CSS instead of display:block and then add an extra line in the JS to show cycler image:active. However, doing it this way actually makes the page loading look worse, even after I compressed the images in JPeg! The rest of the page is displayed before the cycler, and there is a much longer pause before the cycler is shown than I thought there would be, which looks messy. It looks better just left alone to load up as normal! I suppose to do it right you’d have to programme it so that nothing at all is displayed before the cycler, but for the minimal difference you’d get it’s not worth me pursuing that avenue.
Thanks for bearing with me on this experiment of mine! At least I now know about the save for the web in Photoshop, which is much better than the way I was doing it before – I used to upload each pic to an on-line compressor, which was time consuming and is the reason I delayed it until the page was finalized. Now I can compress the images from the beginning.
Oh thanks for the link to the jQuery cyclers too, may use some of those in the future!
Thanks again,
Simon.
