Activity › Forums › Apple Final Cut Pro Legacy › Cross Dissolves Not Working Properly
Posted by Sara Benner on August 23, 2010 at 5:12 pmI have been trying to add a cross dissolve between two clips (with enough time) and for some reason FCP is only letting me put it in as 1 frame. I try to manually go into the dissolve and change the time or drag the dissolve, but for some reason, neither will work. Can someone help me?
Agustin Goba replied 14 years, 2 months ago 7 Members · 9 Replies -
Tom Wolsky
August 23, 2010 at 5:33 pmYou don’t have enough handles on both sides of the edit point.
https://www.fcpbook.com/Effects1.html
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
John Pale
August 23, 2010 at 6:04 pmAre you sure both clips are touching each other? You will see this if there is a 1 frame gap.
John Fishback
August 23, 2010 at 6:40 pmI had this happen to me a while back. As I recall, after double-clicking the dissolve I first had to drag the dissolve left or right (whichever direction you can). Then, you can change the length of the dissolve.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Sara Benner
August 23, 2010 at 7:31 pmThere is no gap between the clips. I have tried double-clicking the dissolve and moving it left or right, but that is still not working. I am at a loss.
Sara Benner
August 23, 2010 at 7:33 pmNever mind. Somehow, I got it to work. Thanks to everyone for helping!
Bob Cole
August 24, 2010 at 12:50 am[Sara Benner] “FCP is only letting me put it in as 1 frame.”
Quite often, I will drag a dissolve into the first shot in a sequence, intending to create a fade-in. For some reason, FCP interprets my action as “Please make a one-frame fade-in.” It’s a matter of precisely where I drop the effect on the timeline. It always winds up working – it just takes a second effort, being careful to hover long enough to see the faint shadow of a properly timed 30-frame fade-in. Once I have a 30-frame fade-in I just drag it back to whatever length is appropriate.
So I have seen this, sort of – but on fades, not dissolves.
Glad it worked out for you.
Bob C
Agustin Goba
June 30, 2012 at 3:38 amYour clips probably aren’t long enough. If one or both of the clips actually ends where the cut is that you are trying to cross dissolve, there isn’t anything there for the software to dissolve into. I.e. FCE needs 15 frames from each side of the cut to create the cross dissolve for a 1-second transition. Those 15 frames don’t come from visible frames in the clips, but from the end portions you have already cut out. If you haven’t cut any frames, there isn’t anything for FCE to create the dissolve from.
For a standard 1-second dissolve, cut off 15 frames from the offending clip or clips, then pull them back together and apply the cross dissolve.
Hope that helps…
