Activity Forums Apple Final Cut Pro Legacy cross dissolves in multiclip editing?
  • cross dissolves in multiclip editing?
    Posted by Troy Lanier on June 17, 2009 at 3:22 pm
    Can I make cross dissolves when editing a multiclip as opposed to the default straight cuts? And if not, is there a work around or way to make all cuts into cross dissolves after I have edited it all with straight cuts?
    Herb Sevush replied 17 years, 3 months ago 2 Members · 1 Reply
  • Herb Sevush
    June 17, 2009 at 3:51 pm
    Troy –
    No.
    Yes.
    Set the dissolve you want as the default transition in the browser. Position cursor at beginning of sequence of straight cuts in timeline. Select all cuts then drag to canvas and use the “overwrite with transition” feature.
    Herb Sevush
    Zebra Productions
