Activity Forums Adobe Premiere Pro Cross Dissolve Problem
  • Cross Dissolve Problem
    Posted by Jason Jammer on March 14, 2012 at 5:36 pm
    Can someone help me figure out when I put a cross dissolve at the beginning of my movie it starts at 100% black, then a quick jump to 80% black, then it cross dissolves into the clip. This only happens after I render. The transition preview is fine.
    I can’t figure out why this jump in black happens.
    I attached a visual example so you can see the difference in the blacks.
    Thanks.
    Alan Peil replied 14 years, 5 months ago 3 Members · 2 Replies
  • Paul Neumann
    March 14, 2012 at 7:50 pm
    Are you sure there are no errant opacity keyframes on the clip? Try fading a piece of black out on a higher layer and see if you get the same result.
  • Alan Peil
    March 15, 2012 at 4:58 pm
    I’ve experienced this, but only when using a Blackmagic Intensity or Decklink card. If you delete all your preview files, then re-render you should be fine.
