Activity Forums Adobe After Effects Cross Dissolve doesn’t translate from Premiere any more
  • Cross Dissolve doesn’t translate from Premiere any more
    Posted by Daniel Christie on December 24, 2009 at 10:36 pm
    I’ve just tried to import a project from Premiere into AE (latest versions 4.2 and 9.0.2.42) and cross disolve no longer translates. There is no black solid to indicate an unsupported transition, but no opacity key frames either. It’s a while since I’ve done this, but Cross dissolve used to translate without issue.
    Any thoughts?
    Regards,
    Daniel
    Brian Horn replied 15 years, 9 months ago 5 Members · 5 Replies
  • Todd Kopriva
    December 25, 2009 at 4:22 am
    It should work. Cross Dissolve is the only transition that should be translated—as a solid with Opacity keyframes. If it’s not working for you, please send a bug report giving some details. You can either fill out the bug-report/feature-request form or send email to aebugs at adobe dot com.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Jason Heaster
    January 14, 2010 at 10:48 pm
    I’m having the same issues with the cross dissolve not importing from a Premiere Pro project. And I have the same version:
    PremPro: 4.2.1
    AFX: 9.0.2.42
    Matrox RT.X2 with driver version 4.1
    The clips overlap once they are imported into afx, but the opacity keyframes do not change. This bug occurs with dissolves of all different transition lengths, and I have tried it with MXF’s, MPG’s, and AVI’s and still get the same results.
    Any new thoughts? I guess I’ll do the bug report too…
  • Daniel Christie
    January 31, 2010 at 12:30 pm
    Still no love. I did file a bug report. Fingers crossed Adobe fixes this, since it is a major upset to my workflow (alot of compositing heavy work and absolutely everything is finished in AE!) I reinstalled AE in the hope that this problem had occured in an update to the Premiere import plug in. Possibly a change to the .pproj EDL syntax in Premiere that hasn’t been communicated to the AE dev. team. That’s my guess.
    I really hope someone is listening at Adobe.
  • Steve Cee
    February 4, 2010 at 5:25 pm
    Have the same problem and it’s killing me to stick all the cross dissolves back in by hand. Some acknowledgement from Adobe would be nice here!
    Steve Cee
  • Brian Horn
    December 7, 2010 at 2:03 am
    I’m having the same issue with CS5. From what I can tell, it creates a brand new solid and puts the opacity on THAT?!
    That would be pretty nutty if that’s as close as it gets. Especially since Automatic Duck does it just fine from a Final Cut xml…what gives?
    -Brian
    http://www.bullbythehorns.net
