Activity › Forums › Blackmagic Design › Cross converting from Decklink?
  • Shane Chadder
    March 15, 2006 at 5:44 pm
    I did this once with a HD 25P job by just exporting the final *.avi in 25P, then creating a new 23.976P job in Premiere and importing the 25P *.avi as 23.976P to print to tape.
    You end up with a program that is 4% longer, but the video should be perfect frame for frame. I dont’ know about 50i and 60i tho.
  • Juan Salvo
    March 15, 2006 at 6:18 pm
    You need to do an HD cross conversion. This requires very expensive hardware, currently only a Teranex or preferably a Snell & Wilcox Ukon. If you’re in New York, GRS has one: https://www.grsv.com
  • Sean Davison
    March 19, 2006 at 3:48 pm
    Thanks Ukon it is then –
