Activity Forums Apple Final Cut Pro Legacy cross convert out problem
  • cross convert out problem
    Posted by Joe Procopio on December 10, 2009 at 8:57 pm
    FCP 7.x, footage DVCProHD, sequence is 720p 59.94….output is supposed to be 1080i 29.97
    view set to 720p, crossconvert out of EITHER Kona or BM cards introduce a single line of green across the top of the raster….AND when going to tape (HDW1800@1080i 29,97) after we set the offset correct, which is a mind boggling +00:00:10, we are off by a field…not a frame..a field…
    all other settings are normal, didn’t change any field dominance on the deck or sequence….
    but…if we go straight out to DVCProHD @ 720, no green line, no frameoffset issues…could the cross convert be causing this field issue?
    for future, I advised the client to use a 1080i preset for the sequence, even though they are editing with DVCProHD footage…
    thoughts?
    Broadway Video, NYC
    AVID/FCP editor/engineer
    Joe Procopio replied 16 years, 9 months ago 2 Members · 2 Replies
  • Arnie Schlissel
    December 10, 2009 at 9:44 pm
    What are you using for genlock?
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Joe Procopio
    December 10, 2009 at 9:49 pm
    question is what haven’t we tried for genlock…in 2 separate systems…lol…1080i, 720p, 525…everything but 1080p…
    Broadway Video, NYC
