Activity Forums Apple Final Cut Pro Legacy Cropping/zooming into a clip while maintaining widescreen bars.
  • Cropping/zooming into a clip while maintaining widescreen bars.
    Posted by Will Leus on June 21, 2010 at 5:48 am
    Hi everyone, just wondering if anyone can help me out with this problem.
    Is it possible to zoom into a clip while having the widescreen bars still in place? I put the widescreen bars on my footage, but when I try to zoom in the clip to crop the image the widescreen zooms in too.
    Will Leus replied 16 years, 3 months ago 2 Members · 2 Replies
  • Neil Sadwelkar
    June 21, 2010 at 6:50 am
    You can place a widescreen mask on a clip by…
    placing a slug on a higher layer
    applying a ‘Mask Shape’ filter on the slug
    set the shape to rectangle
    adjust horizontal 100%
    adjust vertical while looking at the existing widescreen
    set mask shape to invert
    Remove the widescreen filter from the clip on V1.
    So now you have the mask s a higher layer. And you can freely scale, rotate or pan the clip and the mask will not change.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Will Leus
    June 22, 2010 at 9:42 am
    Thanks! I’ll try it out.
