Activity Forums Media 100 cropping wile digitizing component in media 100 HD
  • cropping wile digitizing component in media 100 HD
    Posted by Felix Halter on June 9, 2005 at 5:29 pm
    Hi all
    I am still getting those black bars of cropping on the side of the picture when digitizing from a DVCPRO deck component in to media 100 HD.
    They can be seen at https://www.baldwyn.ch/pages/crop.html
    The bars are not even the same size! There is also a reddish color shift compared to the original.
    If I master to tape and redigitize a second time the right bar gets slightly bigger again and naturally the color shift gets worse.
    Is there any cropping on the SDI input? This would actually mean to buy a new deck with SDI (they are not producing the SDI board anymore for the Panasonic A-D650).
    Anybody has such a board not using this machine anymore?
    This cropping is very annoying. I was looking forward to the media 100 HD but now I’m not so shure if I did the right thing to upgrade.
    Please somebody help.
    Felix
    G5 Dual 2.7 Media 100 HD 10.1.2
    Felix Halter replied 21 years, 2 months ago 2 Members · 4 Replies
  • Floh Peters
    June 9, 2005 at 6:02 pm
    I don
  • Felix Halter
    June 9, 2005 at 8:24 pm
    Thanks Floh
    Yes, the bars are there tn the same size too when digitizing in media 100i 601 mode. And they are not the same width left and right too. So there is some degradation done to the picture in doing this, going from 768 to 720. And the next degradation happens when you crop the picture again in compressor or alike to get rid of the bars. So I guess the best bet would be SDI, but aren’t the bars there too, because all the SDI board is doing is converting the analog signal to digital? Do you have these bars digitizing SDI?
    thanks again
    Felix
  • Floh Peters
    June 9, 2005 at 9:16 pm
    [Felix Halter] “So I guess the best bet would be SDI, but aren’t the bars there too, because all the SDI board is doing is converting the analog signal to digital? Do you have these bars digitizing SDI”
    No, the data on tape (on digital decks like DigiBeta; DV,…) are stored digitally in the 720 resolution; they don
  • Felix Halter
    June 10, 2005 at 4:38 am
    So I hope this is the same for DVCPRO-decks too.
    Thanks Floh for taking your time.
    Felix
