Activity Forums Adobe Premiere Pro Cropping the frame
  • Cropping the frame
    Posted by Areful Eeslam on December 28, 2010 at 7:53 pm
    I shot DVCPRO HD 720PN footage with HVX200. The camera itself shoots 1.78:1 ratio as in 16:9 format. I shot all the footage with 2.35:1 framing in mind. Now i cant change the ratio or rather crop the extra bottom & head using Premiere. Please help…..
    Thanks in Advance
    Regards
    Jon Barrie replied 15 years, 8 months ago 4 Members · 4 Replies
  • Vince Becquiot
    December 28, 2010 at 9:18 pm
    Is your final export going to be 16:9 with 2.35 letterbox?
    If so, just put the file attached on your top layer all along your timeline to mask the extra footage.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Areful Eeslam
    December 29, 2010 at 9:58 am
    thanks for the letterbox
  • Tim Kolb
    December 30, 2010 at 9:26 am
    If you want the actual output file to be 2.35/1, then you’d need to make a custom sequence setting.
    You should start with the DVCProHD setting, as the non-square pixel framesize is 960×720. Then make a custom sequence and unlock the aspect ration and I’d change the frame height to 544 (the number crowds 545, but 544 is divisible by 8, which is a good practice for distribution codecs to handle properly).
    Then, when you put your clips on the timeline, you should be cutting off the top and bottom…though you may get a red line as the footage isn’t actually “native” any more…
    TimK,
    Director, Consultant
    Kolb Productions,
  • Jon Barrie
    December 30, 2010 at 10:38 pm
    I recently posted a tutorial about this type of scenario on my YouTube channel.
    Take a look:
    https://youtu.be/gl6XIPwTa5U
    – JB
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
