Activity › Forums › Apple Final Cut Pro Legacy › cropping still images for use in video (what size?)
Posted by Chris Wright on August 18, 2006 at 5:32 pmThis might be a simple question for many of you, but I am a little confused on what size I should be cropping my still images for use in Premiere and/or Final Cut. I’ve cropped them at 720 x 480, but they look a little bit stretched when I bring them into my video editing program. The pixel aspect ratio is currently set to square. Does it need to be changed to DV/NTSC.
~ChrisKevin Monahan replied 20 years ago 3 Members · 8 Replies -
Shane Ross
August 18, 2006 at 5:39 pmJust for sitting there full size, or do you want to do moves?
For full size they need to be adjusted to 720×534
After you’ve made your graphic, go to Image Size and, making sure Constrain Proportions is deselected and Bicubic is selected, change the height of the image to 480 or 486, as appropriate.
Or, if you want to do movement on them, don’t resize them. Leave them as big as you can and watch this tutorial:
Shane
Littlefrog Post
http://www.lfhd.net -
Kevin Monahan
August 18, 2006 at 5:42 pmCrop to 720 x 540, then save as to 720 x 480. The picture looks squashed at this point.
Import into FCP and place in a standard DV sequence. It will look normal.Kevin Monahan
Take My FCP Master’s Workshop!
fcpworld.com
Pres. SF Cutters -
Kevin Monahan
August 18, 2006 at 5:43 pmShane,
I used to use 720 x 534, but a K-base article indeed says it should be 720 x 540. It’s been fully vetted by Apple engineering.https://docs.info.apple.com/article.html?artnum=301599
Kevin Monahan
fcpworld.com
Pres. SF Cutters -
Shane Ross
August 18, 2006 at 5:49 pmThanks Kevin. I have never worked with stills full screen, I have always done move on them…so this is good to know.
Shane
Littlefrog Post
Kevin Monahan
August 18, 2006 at 5:56 pmThe “formula” comes in handy for titles and lower third elements you make in PS.
BTW, the presets in Photoshop for television are for Adobe products and shouldn’t be used for FCP.The values are different for FCP. Non-square offsets are not universal.
FCP and Adobe have different ratios, but are still within the same spec.Wacky.
Kevin Monahan
fcpworld.com
Pres. SF Cutters -
Kevin Monahan
August 18, 2006 at 6:02 pmSorry: wrong article.
Here it is:
https://docs.info.apple.com/article.html?artnum=36836Kevin Monahan
fcpworld.com
Pres. SF Cutters -
Chris Wright
August 18, 2006 at 6:05 pmThanks Shane. I cropped the images at 720 x 534 as you suggested. I was unclear about why I needed to resize the image to a height of 480 pixels after I cropped it to 720×534, so I ran a test. It looks like the image shows up within the action safe area if I resize the image to a height of 480 px, but that it leaves a black border around the image too.
My conclusion is that if I want the image to fill up the entire screen without the black border, then I should not resize the 720×534 image to a height of 480px, right? I’ll just need to be aware that the main content in my image will need to stay within what will be the title safe and action safe parameters of the video.
~Chris
Kevin Monahan
August 18, 2006 at 6:14 pmI guess you just blew by my post.
720 x 534 is incorrect.Crop to 720 x 540.
Save As > 720 x 480.
The image is squashed
Import the file
Edit it into a standard sequence
The image appears unsquashedIf you are experiencing any anomalies after that, (black borders) you don’t have a standard setup for your sequence.
It should NOT be a square pixel sequence unless it’s HD.
Go to Final Cut Pro > Easy Setup and choose DV-NTSC. Create a new sequence and drop your image into that.If you are unclear as to why you would squeeze the image before importing it is to compensate for sq pixels vs. non-sq. pixels.
Good luck.
Kevin Monahan
fcpworld.com
Pres. SF Cutters
