Activity › Forums › Adobe Premiere Pro › cropping photos for wide screen
  • cropping photos for wide screen
    Posted by Joe Landau on October 12, 2005 at 12:43 am
    I would like to crop a 4:3 aspect ratio photo for a 16:9 aspect ratio wide screen. What shall I set my image size width & Length in Photoshop?
    When I don’t do wide screen, I set it to 720×480 @ 72 dpi. What sre the numbers for wide screen?
    Thx,
    Joe
    Amit Zinman replied 20 years, 11 months ago 5 Members · 5 Replies
  • Mike Velte
    October 12, 2005 at 11:08 am
    My math (720 * .9 * 1.33(PAR) says 853 x 480, but I would not crop it in PS. I would create black bars in the titler to overlay the still, allowing you to reposition the still for best exposure.
  • Redgum
    October 12, 2005 at 1:39 pm
    Or if the still has enough resolution simply crop it with the motion filter.
    Redgum Television Productions
    Broadcast & Corporate Documentaries
    Brisbane, Australia
  • Joe Landau
    October 12, 2005 at 2:41 pm
    Mike,
    Thanks.
    I’m a novice video maker so pardon my ignorance.
    I was always under the impression that to import photos into Prmeiere, I had to use PS to convert them to 720×480 @ 72 dpi (or for vertical yyX480 @ 72 dpi). Always! That’s what I’ve been doing.
    So, when I moved to widescreen I assumed that I must first bring my photos to 72dpi and crop them to fit the wide screen (assuming no motion).
    Which of the above assumptions is right/wrong?
    What is the real scoop on bringing photos into Premiere? widescreen or not.
    Joe
  • John Baum
    October 12, 2005 at 5:10 pm
    You can bring photos of any size in. just don’t bring them in at a larger size then you need as Premiere’s performance takes a big hit if you start adding even just a few large stills.
    Using stills larger then your project size allows you to do pan and scan effects on them. The main reason you would import a picture larger then frame size.
  • Amit Zinman
    October 13, 2005 at 1:22 pm
    I actually use Microsoft Office Picture Manager for cropping and resizing jobs. Why you might ask? It’s that fastest tool around and you don’t have to do the math yourself, it does it for you. Also, free with Office 2003.
