Activity Forums Apple Final Cut Pro Legacy cropping from 16:9 to 4:3, Final project format
  • cropping from 16:9 to 4:3, Final project format
    Posted by Francisco Bech gómez on October 25, 2009 at 8:39 am
    Hello to everyone
    I am editing a project that was shot in DVCpro50 , I want to crop to reframe some shoots since I think they are wide for the characters and make the main charcacter bigguer and less air around.
    I am editing in a DV anamorphic sequeneces
    1) I heard if I edit in 4:3 sequence with black bars in top of bottom I will have more room to reframe without loosing quality. If I do this with what percentage can I work without being noticeable? what if I stay in the original anamorphic preset?
    2) What do you think is the most convenient for the final master? to have the movie in anamorphic, or have the 4:3 format with black bars top and botom
    Best ragards and thanks for your help
    Jerry Hofmann replied 16 years, 11 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    October 25, 2009 at 5:29 pm
    Judge this for yourself I’d say… use an external monitor while you expand the shots to see when it’s unacceptable.
    You should be editing in a DVCPRO50 sequence setting, and I don’t see where letterboxing helps or hurts actually Check it out for yourself I’d say, and definitely look at it externally on a monitor or even a TV set while you expand.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
