Activity Forums Adobe After Effects Cropping after effects layer in premiere
  • Eric Santiago
    April 20, 2021 at 2:14 pm
    Select the AE COMP in the sequence.
    Go to the Effects Control tab and check out the Opacity section.
    On my system, if I double click on the AE COMP it opens it in the Source panel.
    Then I have to open the Effects Control tab. A bit more kludgy on my set-up.
