Activity › Forums › Adobe After Effects › cropping ae comp for flash
  • cropping ae comp for flash
    Posted by Geoff Lillemon on May 18, 2008 at 5:39 pm
    hi there,
    i have a comp that has a looping particle system that animates over 3 seconds, is there a way for after effects to see what the border is for all active moving particles and make the comp that exact size, so that i can export an image sequence with an alpha and not waste file size by having extra alpha data.
    Mike Clasby replied 18 years, 4 months ago 2 Members · 2 Replies
  • Geoff Lillemon
    May 18, 2008 at 7:10 pm
    basically what im looking for is something like the trim tool in photoshop but that does that over time
  • Mike Clasby
    May 19, 2008 at 7:03 am
    Can’t you limit the particle systems area with a mask, like Particle Playground and the mask as a wall, and then make the comp any size you want?
    Or adjust the life of the particles to die before they leave the area you interested in and therefore make the comp any size you want.
    It seems like you would have an idea of what the comp size needs to be for where the animation is to end up, then tweak the particle setup to fit that.
    I guess it depends on what you doing with the particle system.
