Activity › Forums › Adobe Premiere Pro › Cropping a Still Image for use in Premiere Pro
Posted by Chris Wright on September 14, 2005 at 4:21 amCan someone please remind me what size I need to crop my still images that I intend to bring into Premiere?
Thanks.
Steven L. gotz replied 21 years ago 2 Members · 3 Replies -
Steven L. gotz
September 14, 2005 at 5:14 amYou may want to use 720X534 if it is NTSC.
But any size smaller than 4000X4000 should work fine.
Steven
Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
Learning Adobe Premiere Pro 1.5 https://www.lynda.com
Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5 -
Chris Wright
September 14, 2005 at 12:53 pmThanks Steven. Do you ever use the 720×480 NTSC DV preset in Photoshop? If so, how do you recommend using it?
So far I have tried it out by creating a new, blank document using the NTSC preset (which has the 0.9 pixel aspect ratio) then selcting & copying my still image (with a square pixel ratio) and pasting it into the blank NTSC preset document. Then I begin working with that new image to prepare it for my video. Will that give me the same size image that I get when just cropping an image with a square pixel ratio to the 720×534 that you recommended?
Steven L. gotz
September 16, 2005 at 12:21 amIn the newer versions of Photoshop, you can use the 720X480 setting using 0.9 PAR – works fine.
Steven
