Activity Forums Adobe After Effects Cropping a heavily animated comp.
  • Cropping a heavily animated comp.
    Posted by John Winthrop on December 29, 2016 at 4:36 pm
    I make animations with several layers contacting keyframed/expressioned scale/position/rotation etc. This creates an issue when I want to crop in on part of the window.
    My current method is to make a null object, parent everything to it (or if some things are already parented, parent the lowest of them) and change its position/scale as needed. So far this has been working perfectly well but I am wondering if there is another less crude method for this, I have no knowledge of the unified camera tool, is that where I should look or is it more for 3d?
    PS: Putting the entire comp in a new comp and making the crops there is not desirable, I already have many comps within comps so doing this is very processor intensive and results in a loss of resolution (my original footage is 4k, I Shrink it to 1920*1080 to animate, so cropping in on the 1920 comp loses the 4k).
    Any tips/input is appreciated!
    Walter Soyka replied 9 years, 7 months ago 2 Members · 1 Reply
  • Walter Soyka
    January 3, 2017 at 8:13 pm
    [John Winthrop] “My current method is to make a null object, parent everything to it (or if some things are already parented, parent the lowest of them) and change its position/scale as needed. So far this has been working perfectly well but I am wondering if there is another less crude method for this, I have no knowledge of the unified camera tool, is that where I should look or is it more for 3d?”
    Doing this with 3D layers (even if they’re mostly for 2D moves) will let you use a camera for more intuitive control.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
