Activity Forums VEGAS Pro cropping
  • cropping
    Posted by Tom Davicory on December 13, 2008 at 2:37 pm
    Is there any way to crop someone or something and then put that into a different video clip? I.E. if I want a sailboat in a shot, but its not actually in that shot, is there a way to crop it out of a different clip?
    tom
    Tom Davicory replied 17 years, 8 months ago 3 Members · 7 Replies
  • 7 Replies
  • Chris Walsh
    December 13, 2008 at 3:36 pm
    If you’re using Vegas Pro you can use the mask tool and draw a mask around the sailboat and composite it into your shot…or you could photoshop it…
  • Steve Rhoden
    December 13, 2008 at 6:18 pm
    Added to what Chris said: (example) Sailboat on top timeline….
    the shot you want it in on the timeline below it.
    Then use the mask tool to draw an outline around the sailboat, and
    immediately you will see it composited on the bottom layer,
    from there now you do some more tweaking and feathering and
    then you can even keyframe the sailboat movements.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Portfolio at:
    http://www.youtube.com/hentys
  • Tom Davicory
    December 13, 2008 at 11:43 pm
    would this work with sony vegas studio? Its not too important to me, just a convenience issue.
  • Steve Rhoden
    December 14, 2008 at 1:32 am
    Some of the features pertaining to what was recommended for
    you to do earlier, will not work in the studio version.
    Steve Rhoden
    (Cow Leader)
    Portfolio at:
  • Tom Davicory
    December 14, 2008 at 3:48 am
    ok, i got one vid on a track over the other. I used the mask function, but the software help said that next i needed to make a “mask generator” I did that, but i dont see anywhere were I can draw a line around the sailboat. Instead i can change different settings which change the transparency of different elements of the event.
  • Steve Rhoden
    December 14, 2008 at 4:15 am
    To draw a line around the sailboat, Or start masking,
    you need to open the “event pan/crop” window (center
    box at the end of each video clip
    ) and at the bottom
    tick “mask” and select the “anchor creation tool” to start
    clicking around the sailboat to create your mask.
    Steve Rhoden
    (Cow Leader)
    Portfolio at:
  • Tom Davicory
    December 14, 2008 at 3:21 pm
    thank you so much!
