  • Posted by Mike K. kroesen on October 20, 2007 at 2:08 am
    I have a letter boxed Final Cut Pro video that I would like to encode to H264. I want to crop out the black bars so you only see the video program. As if it were shot 16:9 without black bars at the top and bottom of the screen. I used to be able to use Media Cleaner Pro. I would just drag a rectangle around what I wanted to keep and the rest would be gone in the final encoded file. I no longer have Media Cleaner Pro. Is there another way I can do this? Using Compressor or QuickTime Pro or…?
    Mike
    Mike K. kroesen replied 18 years, 11 months ago 2 Members · 2 Replies
  • Craig Seeman
    October 20, 2007 at 2:36 am
    See this on page 151 of the Compressor 3 PDF user manual
    If your source video is letterboxed, use the aspect ratio that matches the
    whole video frame, including the black bars, or else you will end up with distorted
    output files. You can use the automatic crop feature to crop off the letterbox bars. See
    Chapter 21,
  • Mike K. kroesen
    October 20, 2007 at 7:48 pm
    Hi Craig,
    I found it. It worked. Thanks!!
