Activity › Forums › VEGAS Pro › Crop size doubt
  • Crop size doubt
    Posted by Kim Madaula on February 16, 2011 at 10:47 am
    Hi guys,
    I am editing a no budget film. Takes are sometimes better than others, so because my footage is 1440×1080 and my project is 720×576 Widescreen I decided to crop some of them, just to make it really horizontal or to keep out from undesired elements of the set.
    The thing is that I have the feeling that, sometimes, the output video of this takes is a little bit blurry, although I never resize to less than 720×576.
    Another thing thats annoying me is when I look to the crop size info and I see fractions of pixel in the x/y position or wide/length. How is that posssible?
    Is that info reliable or should I try to manually get non fractional values?
    Help will be really appreciated.
    Kim
    Matt Crowley replied 15 years, 7 months ago 3 Members · 2 Replies
  • Ben Edwards
    February 16, 2011 at 5:14 pm
    I simply crop by eye, never worked about the moths and not had any problems.
    You could put a slight sharpen filter on.
    Ben
  • Matt Crowley
    February 16, 2011 at 7:48 pm
    Depending on your preview settings, the output video may appear a bit blurry when you are editing/previewing your project. When you render your project at Good or Best quality the output should be cleaner and sharper, unless the source footage isn’t particularly sharp to start with.
