Activity Forums Adobe After Effects crop + silhouette
  • crop + silhouette
    Posted by Al Chun on May 20, 2010 at 11:45 pm
    Got a video that I have to insert into a window frame of a picture.
    BUT: I gotta:
    1) crop, select portion of video
    2) then make it into a silhouette effect…
    Kinda like you see a silhouetted portion of someone moving inside the window.
    Once the vid’s rendered, I’ll resize it to fit into window. But I gotta do this crop + silhouette thing first.
    Please advise?
    Al Chun replied 16 years, 3 months ago 2 Members · 4 Replies
  • Tudor “ted” jelescu
    May 21, 2010 at 5:53 am
    it depends on your footage- it may be a roto job or just a levels issue- post a still and we can help some more.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
  • Al Chun
    May 22, 2010 at 5:59 pm
    Thanks for your response:
    here’s a still from the vid
    And here’s a link to what it’s supposed to look like. Basically, the site’s in FLASH, but I gotta make everything into html…I’m working on creating the moving silhouettes from the above vid.
    https://www.hotelkasper.com
    Thanks!!!
    May 22, 2010 at 8:21 pm
    The cleanest way to do it is still roto work- draw a mask and animate to match the silhouette.
    However you may still want to try playing with levels to see if you can get a clean enough image (pull color out and get black and white, mask the rest with white- this way you have the jumping man in black only) and use autotrace to get a shape.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
  • Al Chun
    May 25, 2010 at 11:51 pm
    Thanks so much for your response. Im gonna try the latter – levels.
