Activity Forums Apple Final Cut Pro Crop-fit not working
  • Crop-fit not working
    Posted by Orson Kellogg on December 13, 2011 at 8:08 pm
    I’m new to FCPX…. I tried using the Crop-Fit function (which scales up the image inside the crop rectangle to fill the frame), and it worked fine a couple of days ago. Today, I believe I did exactly the same thing but this time the scaling up is not happening. Instead, I’m left with a black area around the image crop area.
    Any suggestions?
    Orson
    Orson Kellogg replied 14 years, 9 months ago 1 Member · 1 Reply
  • Orson Kellogg
    December 13, 2011 at 10:48 pm
    It turns out that I apparently used Trim Mode unintentionally (through fat fingering…) and slipped the image so it was not occupying the full frame but had slipped down and to the left. The cropping scaled it correctly but it was down and to the left without me realizing it.
    I hope this makes sense in case anyone else hits this apparent issue.
