Activity Forums Apple Final Cut Pro Legacy Crop edges to get 4:3
  • Crop edges to get 4:3
    Posted by Daniel Sepulveda on June 25, 2009 at 7:14 pm
    I have a really urgent problem. I`m producing a TvShow for southamerica, which I need to deliver in as files (not on tape). I recorded in different formats, from which the main one was xdcam 1080i. I made the mistake of keeping the timeline at 16:9, but rezised the video to 4:3. This means I have black edges (with no video) at the sides. Now I need to export from FCP without those edges (because its for regular TV emission at 4:3). How can I export croping the edges so I can get the video to 720×480? (right now is at 1440×1080).
    Daniel Sepulveda
    Cámara Televisón
    Bogota-Colombia
    John Fishback
    replied 16 years, 11 months ago
    3 Members · 12 Replies
  • 12 Replies
  • John Fishback
    June 25, 2009 at 9:42 pm
    Try dropping your exported 1080 file into Compressor, and use an SD preset (Prores, 8-bit uncompressed, etc). Turn Frame Controls on and select Best for quality choices. You might have to do some minor cropping. Try it with a short clip first to see how it works. This will take a while to encode.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Daniel Sepulveda
    June 26, 2009 at 1:49 am
    John, thank you very much. Compressor has a feature in geometry that will crop the edges automatically. Great!!! (I know I am kind of amateur)
    Now I just have one issue, even thou it is cutting off the black edges exactly over the border, the images are looking a little bit distorted, wider than the in FCP. I guess the solution is to increase the whole size of the image just a bit so it becomes wider, but my project has 40 different timelines and layers, so I need a way to increase the image size in Compressor from the source (FCP), so Compressor doesnt have to distort the image to fill the 720×480 size. Any idead?
    Daniel Sepulveda
    Cámara Televisón
    Bogota-Colombia
  • John Fishback
    June 26, 2009 at 4:13 pm
    In Geometry, did you use the Dimension control? If not, adjust that for the proper pixel dimensions for your final format.
    John
  • Martin Burlund
    June 26, 2009 at 7:50 pm
    Dear Daniel and John.
    I hope you can help me. Also I filmed and captured in DV 4:3 and put it in a 16:9 anamorphic sequence frame. Now I want it all to just be 4:3 when I export it. I want to get rid of the black bars on the sides.
    Obviously the frame gets squished when I turn of the 16:9 anamorphic sequence.
    I tried to put it in compressor, but I cannot figure it out. Cannot find SD preset, tried with motion 8-bit preset and other 4:3 and 16:9 presets. anyhow it still turns out squished.
    When I export it with 16:9 settings in QT it is not squished, but how to get rid of those bars? Tried to import this file into compressor but still squished…
    I will really appreciate any help. Thanks
  • John Fishback
    June 28, 2009 at 5:23 pm
    Take your export (that’s not squished) and drag it or import it to Compressor. Use the same codec you edited with for your export – in other words, Current Settings. You can export either a ref movie or a self-contained one (do not recompress frames). In Compressor choose a preset that will encode the file into its final format: h.264, mv2, ProRes, etc. Make sure the output will be 4:3. Use the Geometry tab in the Inspector as described above to crop off the sides. Try a short test until you’re happy with the result.
    John
  • Daniel Sepulveda
    June 29, 2009 at 1:49 am
    In case of emergency use Mpeg streamclip and use the crop option on the exported movie. You will need to use trial and error until you figure the values.
    Daniel Sepulveda
    Cámara Televisón
    Bogota-Colombia
  • Daniel Sepulveda
    July 6, 2009 at 9:40 pm
    JOHN PLEASE HELP ME,
    – When I try to export one of my timelines, an specific one, FCP crashes, and says
    Exception Type: EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000008
    Crashed Thread: 0
    – Should my final file be 10 bit uncompressed so it can be handled in Avid? (original material was shoot in XDCAM Cinealta)
    – When I try to export it as 10 Bit, Compressor shows and error in the Batch Monitor, saying the codec is not installed. What should I do? (But it is letting me export as 8 bit
    Daniel Sepulveda
    Cámara Televisón
    Bogota-Colombia
  • John Fishback
    July 6, 2009 at 10:10 pm
    Daniel, I’m not a code guy so I don’t know what that error means. Access might mean memory or drive. If your 8-bit export works, I’d use that. You probably won’t lose too much quality compared to 10-bit unless you have lots of colored areas where you might see banding occur. You might try re-posting with EXC_BAD_ACCESS (SIGBUS)-HELP in the title.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
  • John Fishback
    July 6, 2009 at 10:15 pm
    I had another thought. Have you trashed FCP prefs and repaired permissions on your system drive? You could also trash Compressor’s prefs. Here a link that can help with Compressor problems.
    https://www.digitalrebellion.com/compressor_repair.htm
    John
  • Daniel Sepulveda
    July 6, 2009 at 10:30 pm
    John thank you, I will try re-posting.
    Daniel Sepulveda
    Cámara Televisón
    Bogota-Colombia
